Leaking injector - any known fixes?
BuickTV6
kicking butt Intercooled
hey guys, I have 1 injector is leaking a good amount of fuel. its leaking right where the injector connects to the fuel rail. Is there anything I can do to prevent it from leaking? any sealer I can use on those o-rings?? Anything? I am not in any financial state to purchace new ones and i wanna know if theres something to I can put on it to seal it.
The o-ring should provide a tight fit to the fuel rail injector port. Maybe that injector port is rusty or cruddy and needs cleaning out.
Sounds like the seal(o-ring) is bad. Go to the zone or a local parts store and pick up a set for all 6 injectors should be less than $15. HTH;)
