Latest run with my 84
Nice! This is basically what I plan to do with my car! Probably won't port the heads or intake right away, but I plan to do E-85 and then bigger turbo! hows it drive on the street?
Nice video and nice run. Good to see a hot air running in the quarter. Gives me some idea on what to expect from my build.
Nice. Congrats Bob. What turbo did you end up using?
turbo... still using the ta33 from limit engineering.
tires.. mickey et radial pro 275/60 first run on those tires.
Jerryl.... I am looking to upgrade the turbo. but have to finish my throttle body project. I am going to attempt to recast the throttle body. removing the square mounting surface. cast a v band style flange at 3". bulk up the smaller side so I can bore it to near 3" . keep the 65 mm throttle blade. and have a v band connection added to the turbo I choose. I should have the first piece done about april if time permits.
wahoo...drives great ... I cruise around as often as I can. my favorite quote from anouther buick owner while I was giving him a ride is. " this car is stupid fast and had I not seen under the hood there would be no way you could tell me this is a hot air "
Watching your vid makes me want to play with my hotair 85,000 miles bone stock.
