Kryptonite Billet crank and Parts
bigred121787
Kryptonite billet crank mfg by LA 3.625 stroke has been used standard grind, light bearing material can be polished out shown in pic on ONE journal make resonalble offer...... also have front cover with meziere water pump and oil pump stage 2 TnD shaft rockers, push rods, valve springs, precision 83mm turbo make offers be realistic
Interested in crank any idea of what you want for it ??
Those cranks go for 2000+new (sometimes closer to 3k depending on work done, knife edged, scallop lightened, cross drilled etc ) and fetch around a grand used, if it only needs a polish and not turned down then a grand is good price. It would be nice if it was magged first.
Interested in the front timing cover. Was this on a block with a 14 bolt oil pan? It looks like a 20 bolt cover. What are you looking to get for it complete? Are you willing to separate the components? I'm in need of the Duttweiler oil pump and could make use of the timing cover if it is for a 14 bolt oil pan. So if you are willing I'd like a price on just the Oil pump/lines/fuelpump block off. If the timing cover is for a 14 bolt oil pan then price on the whole unit minus the water pump. Thanks.
I bought this last night.
