My buddy put a new positive battery cable on my car; it was easier for him, since he has a lift. The negative cable was replaced last year.
Now, with the key-on, engine off, I hear a loud buzzing/whistling noise, as if something is running. This is clearly coming from under the hood. The fuel pump runs for a few seconds and then shuts off like it normally does - I've had a hot wire kit on for years.
I've had vacuum brakes for years, and I disconnected the relay for the power antenna years ago, after it broke and it was buzzing with the car off. So that eliminates two more possibilities.
I also disconnected the IAC and stock boost solenoid. I can still hear this running sound!
Is this something related to the starter? Starter solenoid? What could he have screwed up by putting on a new battery cable?
The car runs completely fine if started and driven around. Please help...I'm running out of things to unplug...
