Guys - really appreciate all your help and patience with me. But I'm beginning to lose patience with myself. Here's the latest series of events. No sarcasm meant towards anyone; I'm just frustrated.
Stopped by my mechanic. He hooked up one of his SnapOn gauges (known to be accurate with his others). Has the hoses so I could tape it on the windshield and check to make sure the FP rises with each pound of boost (which I planned on doing a highway run tomorrow). He did put the Schrader valve in since his attaches with it in. (At least I learned what a Schrader valve is today).
Keep in mind my FP was set using the gauge I bought. With his being hooked up, and the car warm to hot, its reading right around 38/39 on vac (whereas mine shows 34/35 when hot), but when we take the vac off on his, the pressure jumps to 47. It was set at 43 using my gauge originally. I haven't made any adjustments yet - figured I'd see what you guys had to say about this.
The other thing is my fuel pressure continues to bleed down relatively quickly. Whether its with my gauge or my mechanic's: turn ignition on. Pressure goes to 42(ish). Without starting the engine, the pressure drops to 30 within 10 seconds, and to 20 within about 30 seconds. Shouldn't the fuel rail be holding the pressure steady? Does this mean my fuel pump isn't working correctly? (Which going back to my earlier posts is only about 5 months old). I see no fuel leaks, and don't smell any fuel.
Next: Driving home with his gauge on my windshield (need to tape it in a better position) so I can monitor FP along with boost. Get on it a little bit, about 8# of boost, and gauge goes right up. So I think great, at least that part is working. A few more times (3, 4, 5?) I roll into boost on the way home. None of these at WOT. At one point I was at about 10# of boost, and all was good on the Scanmaster. The next pull I do and at about 8# of boost, I see knock/retard at 5.3. (I'm not jabbing the throttle, I'm not at WOT, no downshifting - just easing into it and I get that 5.3 reading. WTF??) I do another pull, right around 8# again, and it shows me 1.8 knock/retard. Try one more, about 8-9# of boost, and no knock/retard.
My point above being that its now just become so random, I don't know what to think.
Lastly - and this could just be because I'm a dullard - but when I get home, put in park, let it idle to cool down, when I hit the recall button to see what the scanmaster stored for knock/retard, it doesn't show anything. I know I saw that 5.3 number, so why wasn't it stored? Does the SM only store it if its consistent, or for longer than a period of "x"? I think I read something about the TPS reading "x" for longer than 2 seconds?
@SHADOW - when you say use vice grips to squeeze off the line, what line are you referring to? The only rubber line that could be squeezed off is the vacuum line - the other line is stainless steel. I don't see anything else? (Somehow I feel like I'm going to look like an idiot when you respond to this one!)
Sorry guys. Long write up. Frustrated. Don't have anyone local that knows these cars. And reaching the point where I just want to park it before I do any serious damage.
As always, any input appreciated.
Mike
