monteperformanc
- Jan 15, 2009
Last time I was at the track I was getting a few degrees of KR. So I installed a Powerlogger to see what was going on. I made a quick test hit and I see fuel pressure dropping off towards the top of 2nd gear. It goes from around 70 to low 60's. This is obviously causing a lean condition but what could cause this to happen?
The map sensor is saying 30 psi but the mechanical gauge is saying about 26 psi. Fuel pressure is 40 at idle, 46 with vac line off and plugged.
Car is basically stock with Walbro 255 lph, hotwire, 60# injectors, E85. I have an Accufab regulator and I have heard they can be problematic, but not sure if that would cause the pressure to drop off.
Any help would be appreciated as I don't have any experience with tuning. PL file attached. I see things going south at around frame 661.
