I just installed a Caspers Knock gauge. I has power to the unit since the center green light turns on. Also once the ignition is turned on, the first green light lights up, then just the center.
It doesnt seem to be getting the signal. I ran a wire over to the ECM and tied it into the yellow with black stripe going into the smaller connection on the ECM.
Could it just be it is not wrapped tight enough to get signal on the ECM wire?
I would have to assume the power and ground are working since it does light the center green light.
Did I tap into the wrong wire?
