I finally got my server to come back up. I found this article from HOT ROD on Ken Duttweiler and then editor, John Baechtel's Regal P/SA Stocker. This was a 12.74@106 Hot Air in 1985. If read the article carefully, you will see how amazing this was.
On 17lbs of boost, it produced 364hp and 460ft lbs of torque. He raised the boost to 30lbs and was rewarded with 410hp and 539ft lbs of torque. This was in 1985 . Amazingly he did not blow any headgaskets, but the car did not run any faster .
NHRA was so impressed with car it move the car up 4 classes to M/SA. It also refactored hp from 200 to 225. From the factory this was closer to being the Hot Airs real hp numbers.
Any one with a Hot Air knows that you are running on low boost 8-10lbs of boost, if you are lucky . If you make repeated runs, you WILL lose 2-3lbs of boost .
Duttweiler learned his trade in a Hot Air. From what we know now, he made a huge mistake with gears, 4.56. He also had Turbo 350 tranny with a 10 inch Convertor. He also fabbed headers and a 3" downpipe. He developed the Crane Cheater Cam, 206/206. Other than this, the car was stock! I suspect 4.56 gear made the car stumble as it did. Also, I suspect that 4.56 would make the turbo overspeed itself. The cam shaft moved the powerband up . Amazingly with all this wrong, the car ran 12's in 1985. Ooops, I forgot, he was using the stock chip . Hot Air cars are tempermental, which he found out. In 1986, Buick changed the intake and put in a Intercooler and this changed EVERYTHING .
Assuming that the 10inch convertor slipped, 364hp should have got the car in the 12.40s. 30lbs of boostand 410hp should have got the car in the 11.60 or better range. Brent, Eric Singer, and others running mid 11's are laying down 400+ hp. Amazingly Ms. Jamie and Leeo, both had their hp over 500hp .
Sorry for such a long post, but I thought this was VERY interesting considering before intercoolers became the norm....:
