I'm removing the emissions? tube from the driver side valve cover.
I'd like to use a breather in the valve cover, is anyone else using a breather here and can you tell me what size I need ? Also what should I use to plug the other end on the turbo ?
You will need a K&N 62-1030 breather and a 3/4 rubber water pump cap. You should be able to get the cap at any auto parts store. Zip tie the breather on.
