Car had been inoperable since probably the 90s. I built the engine and it runs now. But not well. It wants to cut out like turning the switch off and back on at idle and low rpm. Throttle blade set, tps set. It will idle and randomly cut out and die. Cruises fine, runs okay in boost.
Bang on or unplug mass air, no effect. Wiggle wires to crank sensor, no effect. Pull chip, idles perfect. Never cuts out or misses.
Is the chip the cause? It is a dinosaur "street lethal" chip, and I know it needs changed, but I want this cutting out fixed more than I care about the chip technology.
