Just pulled the wifes 87 GN motor, will tear it down monday.Just looking for some ideas, she already told me I can't get to carried away ( wants to keep her gas milage). Was looking for some info on injector sizes maybe a chip, have been looking at bigger turbos, not sure if its worth the money for the use. Probably will just send mine in to be gone thru. Plan on just matching gaskets, working the bowl area over bronze guides good three angle valve job lap the valves and back cut a 30 on all . Not sure of the bottom end yet don't want over kill for the use so probably won't go eagle crank, but then I do like to play when I get in it. Will use JE pistons most likely, just to lighten up a little. Have to have the crank sent out to be balanced, no bob weights for a v-6. Any other suggestions that are not to radical for womans toy. Still have to look at cam opptions.
