- May 23, 2001
Went a 10.84 @ 130.1 and a 6.96 @ 101.14 in the 1/8th
20lbs of boost. Its fat down in the low part of 1,2,3 but gets to 10.5-7 right at the end of the run. I have the timing low as well trying to be safe.
Here is the powerlogger file of the run. Any ideas of what I need to change and whats with the boost flutter. I have a low psi actuator and a heavily ported wastegate hole.
This was with a single nozzle with the gain maxed and mix of pump 93 and VP116. Im not trying to blow this thing up.
PLX wideband as well. Will not read bellow 10.0.
Thanks,
Rob Hinson
Thanks,
Rob Hinson
