Just brought a auto meter boost gauge
natedog910
Where do I connect it,do I eliminate the factory boost gauge sensor on the passenger side in the engine compartment or do I install a tee fittings . Do I need to have the factory one connected at all thanks in advance for your help
I just redid this. Mine was getting a shitty reading so I just teed it off to that line near the AFPR and got great vacuum. I'll take pics on the a.m.
You don't need to eliminate the factory gauge, just use a T to tap into the line coming from the MAP sensor and run the new line to the new boost gauge
Just tee in the mechanical gauge to the the map sensor . My question is as the boost is climbing its very erratic not a steady climb to 17 psi ..am quess it's not the boost gauge
