onefastjackass
- Oct 6, 2002
Ok found out the locations of all the other check balls.(Bought a manual)but now the manual says to (install one if one was originally installed in that location)
So my question is above the plate on a BRF transmission was ther originally a check ball just aft of the hole that the TV bracket bolts to.
Once again this is not in the valve body but above the seperator plate and just aft of the threaded part that you bolt the tv cable bracket too.
