Fairbanks aluminum 400 valve body
matt69olds
Ain’t no feeling like Oldsmobling!
I bought a trans at a swap meet that has a Fairbanks aluminum valve body in it. There are no part numbers, it had 2 bolts holding it in place, I’m guessing it wasn’t a running transmission and was thrown together to sell. Anybody in readerland know anything about it? Is it a decent part? Anybody have any instructions? Does it require a special manual valve? Check ball driven into the servo bore? Superior wasn’t much help, the said they don’t ohave information for stuff that old. Thanks
May want to try a Google search if you have not already done so. There is some information out there as it may be linited.
I have done some research, maybe I’m not using the right words find info. I figured aluminum Fairbanks 500 valve body would be pretty obvious. If you found or know of any links I’d appreciate it
I entered "Fairbanks aluminum valve body" as my Google search. Some info popped up although limited.
