scot w.
GNSperformance.com
- Feb 19, 2005
Introducing the Remaster™: A Billet Aluminum Master Cylinder Engineered to Match Baer® Braking Performance.
The engineering team started with a blank sheet of paper to develop a master cylinder that would solve fitment and performance issues faced by builders of street-driven performance cars and race vehicles alike. The Remaster is available with right-hand or left-hand port configurations. An integrated mount for a Baer billet adjustable proportioning valve is machined into the bottom of the master cylinder. The Remaster also features unique screw-on billet caps, making checking and adding fluid easier and cleaner, as well as ensuring that every part of the new master cylinder is of ultimate quality. The Remaster was designed, developed, machined and assembled in-house in Phoenix.
The Remaster is a direct-replacement for other master cylinders, and is available with Ford, GM and Mopar bolt patterns. Standard finishes will be hard anodized and polished. Custom finishes are also available. The Remaster will be introduced with a 1-inch bore, providing an optimum balance between pressure and volume for great braking performance with reasonable brake-pedal effort for most street and performance braking systems. Shortly after launch, 15/16-inch and 1 1/8-inch bore models will be introduced.
NOTE: Call GNS Performance to get the correct application for your braking system.
The hard anodized units will also be 100% customizable like colored bodies, colored caps, colored top plate....
6801238 Remaster Hard Anodized 1” Bore, Left Port - $395.00
6801241 Remaster Hard Anodized 1” Bore, Right Port - $395.00
6801239 Remaster Polished 1” Bore, Left Port - $475.00
6801240 Remaster Polished 1” Bore, Right Port - $475.00
6801244 Prop Valve Brkt Assy (Hard Anodized) w/o Prop - $20.00
6801245 Prop Valve Brkt Assy (Hard Anodized) w/ Prop - $69.95
6801242 Prop Valve Brkt Assy (polished) w/o Prop Valve - $30.00
6801243 Prop Valve Brkt Assy (polished) w/ Prop Valve - $79.95
The Remaster will be shipping starting January 1st 2015. Get your order in now to get in line!
- Compact billet body makes fitment easier while providing the high performance Baer® is known for
- Engineered for optimum balance between pressure and volume for great braking performance with reasonable brake-pedal effort
- Fully machined body with bolt-on mount and screw-on billet caps
- Available with and without Baer billet adjustable proportioning valve
