X2 or maybe a link bar issue? It's probably something really crazy being Richard posted it like this, wants us to use lotsa gray matterAssuming its a cast roller the edge of one roller lifter is climbing up the neighboring lobe.
AG.
+1Lifter bores off location?
Would they not all be shifted in the same direction?
I decided to post these pics today since i figured that after 4 cams in the last couple months with a serious problem i could not expect that i could be the only person that might experience this. I have been building quite a few engines lately and out of the last several engines that have had cast roller cams this problem has plagued 4 of them. This problem has not surfaced on flat tappet cams or billet roller cams that i have put in any engines. These cams have come from different dealers and all of them have been Comp. When the first one surfaced i immediately thought it must be the block. I checked the block ( i have original blueprints of the 109 block to go by) and found the lifter bores to be within a few thousands. First time i had the problem i was setting lifter preload with rocker arm adjustments and noticed that the valve actuation was erratic. After checking I saw that some of the lifters were being actuated by adjacent lobes. The shoulders of the roller lifters were actually riding up on the adjacent lobes and damaging the lifters. I figured that perhaps the cam or block thrust surface might be out of spec. Checking this out revealed that was not the case since some of the lifters needed to be moved forward and some needed to be moved rearward to get "fixed". In each case Comp gladly replaced the cams with another unit that just barely had enough clearance to make me comfortable. They did not seem to care what the problem really was or that it had really caused me a tremendous waste of time.I will comment on this evening
Richard, how far back in time does this issue go?They did not seem to care what the problem really was or that it had really caused me a tremendous waste of time.
the first of these occurred sometime around last april/may all of this has been very recentRichard, how far back in time does this issue go?
No response is another case of the little guy gets ignored.
I'd bet my bottom dollar, had this happened w/ the SBC, LS applications, it would have been "cured' immediately...
Thanks for your headsup!
Richard, how far back in time does this issue go..................QUOTE]
