Originally posted by 1320n10
I have never used a power stroke intercooler but the question i have is that if it was that good why does banks recomend you upgrade the intercooler.
Good question.
In googling for the info., it was amazing some of the claims made, by some folks, change air cleaners, and pick up 50 Ft/lbs, and 104 HP. Interesting claim.
I found these two *claims.
Kind of apples and oranges, but I don't see where adding his I/C was really worth it, for a gas engine.
Oddly enough, things just come in packages so you can only see the differences a whole package makes.
In one claim they mention an 18% decrease in restriction, and a 30% increase in heat disappation. If there's only a 2 PSI drop with the oem one, that means you might see .4 PSI reduction.
While in truck useage, where your at low speeds for prolonged amounts of time, then yes an intercooler that's more effective at lower boost, and lower airflows would be a marked improvement.
PowerPack System
PICKUP/EXCURSION: PowerPack rips the lid off '99-and-up Power Stroke potential, utilizing Banks' exclusive Techni-Cooler intercooler and TwinRam manifold inlet to pack more cool, dense air into engine. The difference is stunning: with top gains of +104 hp, +224 lb-ft torque and 14% improved towing mileage, your Power Stroke can out-run, out-pull, out-perform and out-last any diesel on the planet.
Includes: Lifetime Banks Ram-Air filter and service kit; Techni-Cooler intercooler assembly with powder-coated steel boost tubes, rubber shock mounts, flexible, high-temp hoses and special hose clamps; TwinRam manifold inlet (early '99); Electronic OttoMind engine-calibration module; Quick-Turbo turbine housing with BigHead wastegate actuator; High-boost compressor wheel ('99 1/2 and up); Stainless Monster T.O.P. turbine-outlet pipe with heat shielding; Stainless, low-restriction Dynaflow muffler; Stainless, constant-diameter Monster exhaust with 4" tailpipe; 5" polished-stainless tailpipe tip; TransCommand transmission-management module (4R100 automatics); DynaFact pyrometer, boost gauge and 2-gauge mounting panel; Comprehensive Owner's Installation Manual
Stinger-Plus System
PICKUP/EXCURSION: Banks Stinger-Plus utilizes Quick-Turbo to cut out turbo lag and strengthen turbo performance. Best gains of +91 hp and +162 lb-ft torque deliver more guts when you need 'em, with 11% better fuel economy as you haul a trailer or big load. If you like all that pulling-muscle delivered with a kick, Stinger-Plus is an excellent choice.
FWIW, IMO, YMMV.
