Can any one tell me why were not supposed to put silicone across the entire mating surface of the vally pan style intake gasket??
Use the Right Stuff with the rubber ends. Big blob in each of the 4 corners & a small bead across entire length of the rubber gasket as well. There will be no leaks unless something is really warped or was planed too much to make it not seal.
so will the right stuff work with fuel and alky?
Im just wanting to smear it to ensure no leaks (got an oil burning issue)
