I have everything hooked up and with the instructions that came with the translator box, it says to make sure that the pink wire on the translator box lines up with the pink wire on the maf connector or damage can result. But when plugged in, the pink wire on the translator connector can only line up with a reddish/pink wire on the maf plug. Do i have this wired correctly? This is the only way that it can be plugged it though. Thanks alot, Justin
