i did this.. see if you guys can verify and tell me if i need to change anything..
on stock regals with 3rd brake light, the 3rd and rear lights are on separate circuits as so the 3rd wont flash, okay so we know that.
So what i did was wire a single wire from the brake switch (white wire) to the light.
Then a wire from the light to ground.
works great! bright as hell.. Just hopin this little addon doesnt **** with my alarm or fuses/circuits..
Whatcha guys think?
Do i need to add any fuses or anything?
thanks guys for the help!
At first i wired it to ground, and to a white wire going into the 110V "green block" that was mounted in the trunk under the rear deck.. It had 2 browns, dk blue, and a white wire going into this little block, and some wires out. So i tapped into the white(which i thought was brake light power IN), but it didnt work.. Anyone know why? I wanted to cut the wiring down to where it was wired stright to the available wires right there in the trunk without having to wire to the front.. Know what i mean?
