For what it is worth...when I got my Regal in early July none of the interior lights were working, the PO had stated that he could not get working while he owned the car, even with a replaced dimmer switch. When I went to pull the 5A fuse it looked like it was jammed in crooked. I removed the plastic under the dash in the and verified the instrument lamp circuit, I reinstalled to same 5A fuse with more care to make sure both tabs went into the fuse block connection and all lights began to work and have worked since.
My boost and tach bar gauges did the exact same thing that fgordons did...with the lights off the bars would work, with the lights on they didnt work at all....since straghtening the fuse everything is working.
