jasjamz
THS Racer
- Sep 30, 2004
(6) Used 42.5 pound injectors with Chips, one Turbo Tweak 100 octane AND the Red Armstrong race chip 112 octane $150
(6) Used MSD 50 pound injectors with Turbo tweak 5.6 alky chip $150
(6) Used Green top injectors I think these are 36 pound injectors no chip $75
(6) New Sorensen injectors for a stock 1987 Grand National. New in box...NEVER USED. Part# 800-1011N $100
(1) TE 44 in need of complete rebuild $150
(1) PT-51 in need of complete rebuild $150
(2) NEW never used Red Armstrong "RACE 009 F7599H" 107 CHIPS (Designed 22 PSI boost or more). Never Used $30
(1) Brand New EZ-LINK AUTO XRAY Diagnostic SCAN TOOL FOR GRAND NATIONAL and GM VEHICLES 1983-1995 OBD-1 12 PIN CONNECTOR $50
(1) New in box 2 1/16 VDO Water Temperature Gauge. Never used. $40
(1) Auto Meter hood mount fuel pressure gauge. ( NOT FOR GRAND NATIONAL ) $35
(1) Used Autometer 3411 Fuel Gauge complete with cup and adjustable exterior hood mount band & bracket 1-15 PSI (For carbureted cars...not for GN) $50
(2) MOOG stock replacement rear springs for 1987 Grand National with less than 250 miles.$60
(2) Rear Gabriel Gas Ryder Shocks with less than 250 miles.$40
(2) Stock Used 1987 GN Rear Lower Control Arms $30
(1) Stock Used 1987 GN Rear Sway Bar$30
(1) Used Factory 1987 GN Coolant Overflow Bottle $10
(1) 1987 stock intercooler and shroud with 32K miles. Intercooler worked well when it was removed from car. Shroud is torn on one corner, but is repairable.
$100
(1) Used Powermaster that worked fine until I started the car up after a long winter. The brake light came on...it started smokin'....I switched to vacuum brakes...END OF STORY! $100
I also have a complete set of Autometer Carbon Fiber Gauges. These are new and never used. i took som out of the packages to check fitment into some pods but thats it. Here are the part numbers so you can compare the prices:
Speedo -4889...$200
Tach -4894...$220
Fuel psi -4763...$180
fuel level -4715...$40
pyrometer -4744...$120
trans temp -4757...$40
oil psi -4727...$60
volts -4791...$40
water temp -4737...$40
Some Autometer pods available too but I have to see how many I have.
Post here to get first dibs then email me please! this will keep things in order for everyone to see.
Shipping Is Not included
Paypal preferred and my email is jasjamz4@yahoo.com. My inbox is just about full here on the board. Thanks for looking!:biggrin:
$100
Speedo -4889...$200
Tach -4894...$220
oil psi -4727...$60
volts -4791...$40
