Just finished head gasket job # 5 cylinder let go and upon start up the car ran like maybe plug wires crossed? Confident they are not blms are 150 pegged on friends OTC.Compression check showed 150-155. Friend said start the car and pull injector plugs one at a time and if the car starts to miss more go to the next one and if the car runs the same probably bad injector,plug or wire.# 5 car ran the same! Question is injector quits car goes lean blows head gasket ??
Thanks Burner
Thanks Burner
