I need to understand the wiring instructions for the FAST. I see the instructions on the FAST site and according to that here is the way its layed out.
I'm using a Small block Ford configuration.
A Black
B Blue
C Purple
D Gray
E Yellow
F Orange
G Green
H Brown
It also says the following injectors should be plugged in.
Clylinder 1 is yellow
Cylinder 2 is Brown
Cylinder 3 is Orange
Cylinder 4 is Purple
Cylinder 5 is Blue
Cylinder 6 is Black
Cylinder 7 is Green
Cylinder 8 is Gray
I think I understand this, just one question.
For all this to work, does the female plug side of the harness supposed to follow this order
A Black
B Brown
C Yellow
D Green
E Orange
F Blue
G Gray
H Purple
I guess what I'm getting at is that I"m going to eliminate the connector together and solder the wires. IF I understand this correctly this is what I need to do.
Solder Black (Female side) to Black (injector & Male side)
Solder Brown (female side) to Blue (injector male side)
Solder Yellow (Female side) to Purple (injector & Male side)
etc
and the use the following plug to the above cylinders.
Anyone?
A Black
B Blue
C Purple
D Gray
E Yellow
F Orange
G Green
H Brown
Cylinder 2 is Brown
Cylinder 5 is Blue
Cylinder 6 is Black
Cylinder 7 is Green
Cylinder 8 is Gray
A Black
B Brown
C Yellow
D Green
E Orange
F Blue
G Gray
H Purple
etc
Anyone?
