Injector Problems. Help needed.
crazqban
The Power of the DarkSide
Hey guys,
I have a friend that has a very strange thing going on with his 86 GN. It seams that all the injectors are pulsating at the same time which is causing the engine to flood with fuel. Could this be possible? And if so what could be wrong, that is causing this to happen? :confused: :confused: :mad: Have any of you ever had this problem, and if so what did you do to fix it?
It is so bad that the engine gets full of fuel, and the fuel comes out of the turbo, gets into the oil, and it even floods the spark plugs. Your help will be greatly appreciated.
Thanks to all in advance.
How did you determine they are all pulsing at the same time? Have you checked the injector harness for shorts?
