On cold startup the car misses slightly, then kind of smoothes out for about a minute then dies. It will continue to do this until it is warm. The coilpack secondary resistance checks O.K., fuel pump and filter have been replaced. TPS=.44, IAC=11, O2 is all over the place (.1-.8) and CC are very low 1-10. The O2 sensor is new. Keeps going from rich to lean on snap-on scanner and BLM is high 130's. Plugs and wires are also new. Plugs are wet when I pull them for inspection. The car doesn't feel as strong as it should be.By the way, it is a 87GN. Any help would be greatly appreciated!
