I thought when you replace old with new it should work like new....no?
I just replaced my old window motors which were working very slow replaced the D/S hinge pins and I also replaced all my mouldings (belt mouldings,door moulding and roofrail mouldings. Now here is where I am having a problem. Yes they look good,but for some reason my windows will not go all the way up when the door is closed they hit the moulding then stop. Also the windows do not seal perfect on the new moulding. I understand the car may be a little out since it is a race car, but the old stuff was fine just ugly.
Is there some kind of adjustment to the window which will push it in towards the moulding? I am frustrated because I just spent the money to fix the problem and now i have more. Also what aire is the one that needs to be replaced on the window motor that causes them to slow down? Any help or suggestions I would appreciate.
