Occasionally when I turn the key absolutely nothing happens. No starter click, no fuel pump whining, nothing. Then after about 1/2 second the car starts normally. The car has 215,000 miles so things are starting to wear a little bit. I'm thinking it is the ignition switch with the rod from the key switch. I purchased a new switch so I would know what to look for. I looked up from under the dash but couldn't find it. Should I drop the steering column and if so, whould I be sitting in the driver's seat and then just reach over and remove the switch? Or is there more to it than that? Thanks.
