C
Cakes
Guest
When first started my car will start up normal and then idle down to normal engine idle (either in gear or not) it will then go down below normal and begin to sputter and then stall. I adjusted the IAC and TPS according to gnttype.org. Does anyone have any suggestions on what else to look for? It also drives fine once the car is moving. It just seems off idle it runs bad. Also after blipping the throttle a few times it will idle fine in gear and in park. Thanks
