My other thread has pics of most the stuff, but i have pics of everything so just ask. These are the things i can think of off the top of my head that are included, im probably missing a couple things so just ask to make sure.
*does not include stock ecm, sold that with my powerlogger. They can be purchased for under $100 though.
*you will probably need misc nuts and bolts, im including everything that i did not reuse with putting the L67 into my car.
Priced to sell at $1200 plus shipping, this is cheaper than any time ive seen it on here. I bought less parts than what im letting go, for 2000 2 years ago
INCLUDES:
ac delete pulley
alternator
battery cable
boost solenoid
cam sensor and shaft
coil pack
knock module
relays
map
crank pulley w/o ic fan
crank sensor
cruise control servo/cable/wiring harness
headers/ STAINLESS xover
electric fan
engine balancer
engine timing tab
engine harness
flywheel
front engine bracket
ac bracket
coil bracket
fuel injector harness
fuel lines
fuel rail with regulator
right and left frame side engine mounts
upper intake manifold and tb
both valve covers with breather
oil dipstick and tube
power steering pump and reservoir
return fuel line
speedo cable from trans
starter
stock turbo w/ported shroud and rebuilt
supply fuel line
tensioner (has little crack but works fine, have pics)
throttle cable
throttle cable bracket
turbo oil return tube and fitting
turbo support bracket
lower intake manifold
stock up pipe tapped for alky
water pump pulley
all the misc bolts i have that came off the car
stock IC setup minus fan
INCLUDES:
ac delete pulley
alternator
battery cable
boost solenoid
coil pack
knock module
relays
map
crank sensor
electric fan
engine balancer
engine timing tab
engine harness
flywheel
ac bracket
coil bracket
fuel lines
return fuel line
starter
supply fuel line
throttle cable
water pump pulley
