1967 GeeTO
- Oct 26, 2003
Is there anything special when replacing the IAC (mine broke while removing it to clean it)? After I insalled the new one, the numbers were way off - somewhere around 100 at idle with the tps at .40-.42 per my Scanmaster. I tinkered with it and the tps for about an hour and am getting the numbers closer, but still have more adjustments to make. Is this normal? Does it matter how much you tighten the IAC down as long as it is tight?
Also, what should approximate rpm be at idle? I'm getting the numbers closer, but sometimes turning a high idle rpm (1500).
Thanks, Sam Williford
