Why not make your own E85?
spyrs69 said:
I seriously want to run E85 in my 87 GN. The current gas prices, supporting the arab nations and cheap 105 octane are my reasons.
I know I will need to swap out any rubber hoses and probably the Walboro 340 pump I just put in (right?).
I have aftermarket 50# injectors and the rest of the fuel system is stock. Is there anything else I would need to change?
Thanks.
Why don't you just make your own E85? That's what I'm doing...
I'm on the same path to an E85 fueled GN. So far I've got the still almost finished, bought a boiler, fermenting tank, some yeast, and a hydrometer to check the proof, should be fermenting the first batch in the next couple weeks if time permits. It'll be 190-195 proof outta the still then dry wash it over night to remove the last 5-10% water and bingo you have 200 proof alcohol (100% pure alcohol).
As far as the fuel pump is concerned I'm on the trail trying to find out what the PUMPING specs are on the 2005 Chevy 1500 pickup-they all have a FFV (flex fuel system that will burn E85) system from the factory, and IF it can pump enough fuel the fuel pump problem will be solved. The FFV pumps can be bought on ebay. Then on to the rest of the fuel delivery system.
Copper has been suggested for the fuel lines? (easy to bend and will withstand the pressure as well as the ethanol), don't know about that one!
There is definitely going to cost involved but according to the E85 makers/users it can be made for less than a dollar per gallon, depending on availabilty of feedstock. Quiet a savings wouldn't you say?
I'm hoping that the translator + that I have on my car will be able to adjust for the extra E85 fuel needed to run the engine, if not I'll contact either Eric or Bob for a chip that can handle the E85 stuff.
If anyone knows how to get the fuel pump PUMPING specs on the 2005 Chevy 1500 pickup fuel pump, I sure would like to know.
Good luck,
Jerry
PS The nice thing about making your own fuel, if you have any left over from a fillup you can drink the rest!!!! It's not nice to waste good fuel:>)
