turbowidow
- Nov 15, 2003
finally got around to checking motor,here is what i got.
#1. 140psi
#2. 150psi
#3. 154psi
#4. 148psi
#5. 150psi
#6. 140psi
performed the test on the motor cold(about 45 degrees F in garage),plugs out,charger on battery to keep volts constant,throttle held wide open. i'm planning on doing valve springs but with the above numbers not sure if i'd be better off doing something else first. car is a 1989 tta w/ 42k on it, never been opened up w/ basic upgrades. need suggestions on what to do next!
#1. 140psi
#2. 150psi
#3. 154psi
#4. 148psi
#5. 150psi
#6. 140psi
