A few weeks ago I decided to replace the brake fluid on my 86 GN. Although the brakes worked fine, the fluid looked brown, I know it was old and the brake pedal was soft. For all I know it might be original. I still have the Power Master, and I bled them like regular brakes. I pushed about 2 quarts of fluid through to be sure I replaced it all.
I drove the car around the block a few times and brakes seemed fine. Then I noticed brake fluid on the garage floor. I checked the level in the reservoir and the level had risen to the very top and had overflowed. I remove some fluid, pumped the pedal a few times with the engine off and the pedal firmed up. I didn't drive the car, but checked back a few days later and pumped the pedal again with the engine off. I heard a hissing noise, and found the reservoir overfilled again, and fluid was dripping off the side of the M/C as I pumped the pedal. I opened the resrvoir and the half toward the passenger side looked like a milk shake. I removed some more, and let it sit. After it looked normal, I repeated pumping the pedal and it turned to milkshake again, again only on the passenger side of the reservoir. I did it a few more times, and it stopped overflowing, and looked OK.
Then I started the car to try the brakes. When I started it, the brake light was on, and I could hear a buzzing coming from the PM. As my son pressed the brake pedal, I could feel and hear it in the unit.
Does anyone have any idea what happened? Any and all suggestions will be greatly appreciated. Thanks.
