When I first got this setup together I was lucky to get 10 pounds out of it before knock occurred with my stock TT chip settings (20-18°)...now I have pulled out most of the advance and got the boost up to 18 pounds and 11.0 afr and the thing runs wayyyyy better than 10 psi with the higher timing....why are most ppl running such high timing? I can't wait to get good gas back in it and set the boost in the mid to upper 20s with about 15-18 degrees advance and see where it is....
Just an observation
Just an observation
