I have sat back for 5 years now, unable to afford any kit that would greatly increase my airflow. Here is what I have seen:
V2 kits, js kits, spearco kits and so on. What have I heard? not one of these cars breaking into the 11's. i KNOW for a fact that $$$ is almost always an issue with everyone...especially when it comes to cars. If someone has broken the 12.00 barrier with a kit bought off of these boards, they should come forward....
What have I seen instead....hundreds of cars taking a stock intake and head combo, porting them, and boom...12's...and turbo6x2 going to the smaller side of the elevens, and lee t running 10s with hot air and tons of alky...but was it all alky pushing that 10.8 (is that correct?)? no way...it was a worked block, tons of porting and experimenting with different turbo/porting/alky combos, and yielding the fastest hot air on all of the boards...with out an IC and without any kit or doghouse. I am a stout critic of those who intercool for the quick bang for the buck. I had an IC car, it was fast and fun, but it went out with my roller hot air to pay for a house. Now my twin and I are building a 84 t-type in his garage, and it will look entirely stock when we are done. aside from the poston headers adn atr exhaust...the top end will look nearly stock. but underneath, two nozzels of alky...fully ported intake and heads matched...204 cam, ported TB, possibly a TA 60 turbo stock mounted and adapted, and a bunch of other upgrades, but totally stock appearing!!! the turbo will be bigger yes, but i will be clocked the same as the original, located in the exact same place, and forcing the "hot" air through the massive ports in my intake. no dog house argument....no IC to bend piping to...nothing to modify on the top end except the turbo clocking and an adapter for the TB.....
In a year, maybe less, i will post the results...his car, totally stock from 1984 to 2004, ran a best of 15.18 in 2004 before a terminal rod-knock started.... that was at 15 psi, a tank of 94 from sunoco and an octane booster off a shelf at a local parts store....only mod was the adjustable wastegate.... mods for the car this year: 50lb injectors, carter chip, 2 stage alky, TA60, adj wastegate and accufab fpr, bored out TB, ported intake, ported heads, 204 cam/timing set, .030 block with forged guts, kenne bell oil pump kit, blocked EGR, poston headers and x over, atr up and down pipes, test pipe, dynomax catback, 3200 stall converter, walbro 340, alum f-bod rad and 87 fan, trans cooler, oil cooler, and the biggest mod to date....fuzzy dice that match the exterior!!!! so...what do you think? worth all the work over a doghouse and IC?? time and $$$ will tell!!!
John
