My two cents:
If I was building a motor I wouldnt ever go hyper pistons for a turbo car. I rebuilt my engine at Wyotech, only to find out that the 43K 85 block that I drilled and tapped for 86-87 oil return line had no ring ridge, everything is standard. The rings still had their "sharp" edge to them. Im currently still running stock pistons and rings in a ball honed block and am running 22 psi at the track.. Car's gone low 12's and there's room for even more out of it.. with hyper pistons you can run a goood amount of boost, you just need to match that with enough fuel so there's no detonation causing grenading... RJC power plate helps, along with good intercooler and upgraded fuel pump and injectors. Though I wouldnt suggest going hyper if you're buying new pistons anyways, it maybe all one can afford.. Just generous with fuel and dont go to lean on your tune.
