Gents,
i just recently swapped my sourmaster over to hydroboost. got the remanned h/b, master cylinder, and ps lines from autozone for an 84 gn. (yes the factory 84-5 lines worked just fine with a little persuasion) heres the problem: my p/s pump is LOUD!!!! even at idle and gets ungodly loud under load, especially braking. another thing, my brakes are not quite right. i can push the pedal about halfway to the floor and the brake grab increases linearly like it should, but after about halfway, they seem to be maxed out, they grab pretty good, but its not even close to locking up the wheels, and the pedal resistance gets much lighter and doesn't change from there to the floor. also, i essentially lose power steering while applying the brakes.
i hope that description isn't too confusing lol.
i have bled the brakes and they are good, today makes the third day in a row of driving around the block and seeing mass amounts of foam in the p/s resevoir. so for the third time, i will let it sit and settle and top off the resevoir. is my p/s pump failing, or is there just air in the system or what?
any expertise in the field would be much appreciated.
thanks in advance, gentlemen.
Talon
Talon
