To hell with the drawings machine me up those spacers and Ill send you a green gift.
Well looks like the price for the three-piece kit is running between $215-275.00. This would depend on the number ordered, (low limit is set at five with a high limit of 20.) I would require half of the cost upon order with the balance due at shipment.
The kit would include:
1- 6061 Al spacer plate 1.25" thick.
1-530B adaptor plate
1-Pedal spacer
4-Socketed cap screws w/ washers and lock nuts
Detailed instructions.
A list containing part numbers of the hoses, master cylinder options and a list of hydro boost units that can be used.
You will use the stock pump that is on our cars now.
Let me know if there is still intrest out there...
So after buying your kit how much would we have to spend with autozone to make this work? No fab work right?
Put me in if we can go 200 shipped.
Theres an astrovan hydroboost unit that dosent require a spacer on the pedal to work i used it on my setup which is slightly different than yours...I just havent a clue as to what year the truck was i took the unit off of....Id also spring for the earls power steering an fittings and use teflon braided line....also its a really good time to add a line loc and you will probably need to make a bracket to lower the power steering reservoir so you can get the cap off.....Nice setup you got there btw...
x2 it is cool to see the mod evolve. Id seen others space it out from the fire wall so you dont need to mod the brake pedal rod. cool for someone looking for a drop in kit. you'll never look back one of the best mods I have made.......good work
