B Barberman91 New Member Joined Jun 19, 2018 Jun 27, 2018 #1 Looking for one center cap for my 84 Riviera t-type. Feel free to email me at barberman831@gmail.com thanks Attachments s-l225.jpg 13.1 KB · Views: 86
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jun 27, 2018 #2 Have you check... partrequest.com or Ebay, you should be able to find it there.
B Barberman91 New Member Joined Jun 19, 2018 Jun 27, 2018 #3 I see a few on eBay, do you know if the black emblem comes out of the hub?
Buckshot G/N Well-Known Member Joined Nov 2, 2011 Jun 27, 2018 #4 I'm pretty sure on the OEM caps there just glued in the caps, you probably could removed it by squirting a little 3 in 1 oil on it around the brim, an gingerly prying it up. but probably be cheaper to replace it.
G Gary Durden Active Member Joined Nov 17, 2002 Jun 28, 2018 #5 You could also try a hair dryer and heat it up and then easily try to pry it off. Good luck.
B Barberman91 New Member Joined Jun 19, 2018 Jun 28, 2018 #6 Thanks mine is shattered so it should be easy to remove.
B Barberman91 New Member Joined Jun 19, 2018 Aug 3, 2018 #7 So I purchased one off eBay and it ended up being tiny compared to mine. All the others on there seem to be the same Attachments IMG_20180803_185812.jpg 3.4 MB · Views: 41 IMG_20180802_084244.jpg 4.2 MB · Views: 41
