Not being an expert on the progressive system because I don't have one I thought it was a linear ramp from your turn on point to the max. reading point. Perhaps the slope of the voltage is adjustable in the controller. Still a linear ramp however.
I am sure I will be corrected if wrong.
I think you can do just as well if not better with staging and multiple nozzles and approximate the more parabolic flow my poor tired old motor needs and I am not running my injectors static or shooting for the 10's either, hence my non-linear comments
Not looking to pop my original headgaskets any time soon either.
And as to hypothetical failure modes boost contol is much easier to achieve than most people think.
What happens when a one nozzle system plugs or gets partially blocked? Massive loss of octane and cooling.
At least my other two nozzles would be flowing enough to save my headgaskets.
If you can install a home made hot wire system you can install a simple staged system and use your current DIY pump or SMC kit as well to work with.
I have nothing wrong with any way of achieving good alky. flow in a motor I just won't say any one way is better or mandatory to use over another.
Alky. is the only way to fly on the street and fun to use for racing as well.
Hopefully someday a true street car class will emerge at a big event. I really think it would garner the largest participation of any race class and be the most fun.
