Originally posted by Medbull
I am currently running a stock TB. How much of an up side would there be to using a bigger one? And if I should go bigger.....How much? Thanks for your help. Combo is in my sig. John
In one afternoon, I tried switching all the plumbing from the turbo to the plenum.
Stock TB
62
and 70
Also since I was running a I/C delete, I was also able to run different sized up pipes. 2", 2.25", 2.5", and 3.
While some folks are just worried about WOT, I'm of the sort that likes having as much as I can while retaining pretty good manners. So my worry was about drivibility. But I can tell you that for my 206/206, 3.8L, 55 PPH, 60 turbo, stock convertered, car.
The smaller TB and piping allowed for faster initial spooling. And progressive throttling up to including WOT.
As I increased the TB size, spooling slowed, but initial throttle response was *faster*. But it wound up taking tinkering with the Accleration Enrichment, and VE table to get it correct.
Trouble was that at say over 3/4 throttle with the big throttle body there was very little actual throttle modulation available.
For me, and my car the 62, and 2.5" setup is what works for me.
If you're going to try to do accurate back to back TB testing then you also need to figure in the differences in % TPS, and spend a bunch of time getting the AE, and PE stuff optimized.
So you might go a lil faster, but it's doubtful it'll really slow you down, if the tune is optimized for the big TB. But, you'll lose the ability to modulation near WOT openings.
And on a related note, the rate of change of the TB and HP is relayed to the tranny via TV cable. So if your tranny isn't up to it, you might shorten it's life.
Again, just what I've found, YMMV.
