Y YAKO Member Joined May 19, 2011 Jul 28, 2012 #1 Hi ,I just took apart my 109 stroker and am wondering since the arp bolts are already streatched in the K1 connecting rods what torque can i use on the nuts with a standard torque wrench also i have studs in the block for the main ...THANKS
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Jul 28, 2012 #2 arp lube- torque 30 lb/ft - then torque additional 60 degrees (1/6th turn) not that it matters but i usually end up seeing about 55-60lb/ft on the digital
J J-B Racing Forced Induction Joined Sep 16, 2003 Jul 28, 2012 #3 http://www.campbellenterprises.com/...ng-rod-bolt-torque-stretch-assembly-specs.php
