How much oil are you running in your LC2 with the PTE oil saver AND RJC deep sump oil pan? I know the PTE oil saver adds up to a quart capacity when using the Baldwin B279. The DSOP add up to 2.5 additional quarts. This comes up to over 8.5 quarts of room. I know that a lot of racers run lower amounts of oil to help reduce windage on the crank, but on a dialy driver car how much oil would you run?
