This is a LITTLE engine, it's not a 454, or even a 350. It will only flow a limited VOLUME of air. The turbo inlet may be big, but the turbo is a COMRESSOR, it squeezes the inlet volume into a small package, so the little engine can digest it. You're looking a something under 500 cfm, even if you have a cam, ported heads, etc. You may have 1000 cfm into the turbo, but look at the difference in size between the turbo inlet and the turbo outlet. The small volume of dense air doesn't need a humongous throttle body to get the right flow velocity. The power plate is a good idea, though. Big throttle body won't hurt anything, it's just not the most effective use of your money.
