litdog83z said:If it goes bad I know it can limit boost to 10psi with a stock wastegate actuator, but can it also cause overboosting? Can a custom chip control the wastegate solenoid and raise the boost a lot?
Ormand said:I've been using a Thrasher for years, and reading the info on several of the Buick boards for years, and this is the first time I ever heard the suggestion that the Thrasher keeps the waste gate solenoid "chattering away at 100%". I'm aware that the Thrasher has a "lean cruise" mode, which also helps in quick spool, but I don't think that involves the waste gate solenoid. Also, at 100% duty cycle, the solenoid would be continuously OPEN, which is somewhat different from chattering.
I believe you'd have about 10 PSI of boost if you reversed the "Y" fitting. If you're going to use a manual boost controller, leave the wastegate solenoid hooked up, because the ECM monitors its electrical function.Quick6'n'-K.C. said:....Snip....I have never installed the Y fitting backwards,... i dont know what would happen....
BW
