HOw much boost?
Kyle F
Addicted to Boost
HOw much boost can you get out of the Stock turbo with an adjustable wastegat and an Alky kit on pump 93 gas? I Have been wondering what times I can run on the stock turbo using an Alky kit,adjustable wategate, Down pipe and exhaust dump, cold air kit and MAF pipe. A Walboro(sp?) Fuel pump,Adjustable fuel pressure regulator and getting it all dialed in with turbo link and putting to the ground with a DOT approved drag radials?
I was running 20psi on Sunco 94 octane and an 18 degree street chip. I dont see why you couldnt run 21-22psi with alky. The turbo is supposed to be pretty much useless after that amount of boost anyways so start bringing the timing around.
Sounds like my setup without the downpipe and dump. I think it would be possible to run 22psi and get 12.0's pretty easy once it is tuned. possibly even into the high 11's
