How much boost should I run?
my1stgn
I justed wanted to see how much boost I should run or what is the sweet spot of a Dual Ball Bearing PT6176 P-Trim Turbo? Im running Alky with a TT Chip and stock torque convertor, stock I/C with dutt neck mod. Eventually I will upgrade tc with trans rebuilt.... also what stall speed should I shoot for? Thanks!
If it ever spools you should be able to run 24-27psi no problems... I would say a 3000 but you may can get away with a 2800 is your tune is dead on...
