As air temp goes higher you need to advance the timing to regain the cylinder pressure lost do to the air being less dense.
So as the temp drops you then need to retard the timing.
As air gets cold the barometric pressure goes up.
Which means there is more exhaust back pressure. So you need to SLIGHTLY lean the fuel down as baro raises.
The stock MAF uses an entire table to compensate for IAT/MAT changes. For some reason they left the timing vs IAT/MAT table all 0'd out.
If all you have to tune with is adjusting the wastgate then that's your only cure.
Where as the proper cure is correcting the timing.
Removing screens, and such can also skew the MAF calibration to where you can get to no mans land.
